Considering buying a C5 X7 2010 Auto 64K on clock.
falling-out-with-my-car
x 25
Unread post by falling-out-with-my-car »
Hello,
Can anyone help please with some pointers of what to check on a
Citroen C5 X7 Automatic as I am going to view it on Saturday 18th of November.
I have paid a refundable deposit of £500.00 for the Garage to hold the car for me.
They are LMC Citroen A Main dealers.
it is a 2.0l hdi Automatic estate exclusive Having done 64,000 miles. as I know very little about Autos
The vin number is VF7**************[VIN obfuscated, can be read by forum staff] if it helps.
I would very much appreciate any advice on this model as in things to check for when viewing please?
My Introduction into C5s with my Manual Mk2 which will be part exchanged if I buy this Car has been very positive
except for my driving abilities complicating things a little. hence the change to an Auto which will be adapted for me.
Could somebody enlighten me as to what it costs to tax please as I shall have to have this done when collecting the car.
I have to watch the figures as I am borrowing some money to cover the cost.
I will change my Monica soon as I have sold my 2cv to help round up some funds to buy an X7.
Many Thanks in advance.
Nigel.
x 6950
Re: Considering buying a C5 X7 2010 Auto 64K on clock.
This is a 2.7 Litre V6 Nigel: C5 (X7) 5 DOOR ESTATE 2.7 HDi particle emission filter BVA AM6
£305 tax and insurance Group 31.
23-33 MPG - 33 being the 'combined' consumption.
As for advice - have a look at this thread.
https://www.frenchcarforum.co.uk/forum/ ... ering+rack
There are other threads that have covered most of the issues too.
x 3565
Steering rack. Steering rack. Steering rack. Those would be the first three things I'd want to know about :) A rough idea of the rack pinion condition can be gauged by looking through the driver's side wheel with a torch....... if you know exactly where to look, but for a better idea it needs a look from the driver's footwell, and that needs a bit of trim to be removed. A 5 minute job if you've (they've !!) got tools to hand ! You need to know if the rack's been replaced at all / if the pinion is rusted at all / if any form of warranty they offer will DEFINTELY cover a replacement rack due to failure of the pinion seals due to rust. If they're not prepared to confirm anything then you might want to either getting a proper AA / RAC / independent inspection report of the car, or think again. It's not terminal if the rack goes in your ownership - recon racks can be fitted for around £400 if you find the right garages..... but I suspect you'd rather not have to pay for a replacement rack at all :-D I think Citroen charge well north of £1k to fit a new rack.
The only other thing I'd check for is if the front windows go up and down without too much noise. There have been an awful lot of failures of the window winder mechanism cables. It's not a particluarly costly or difficult job to replace them - but again, I'm assuming you'd rather not do the job at all !
You might also want to consider getting a partial oil change done on the auto box in due course. There's plenty of (recent) info about that on the forum. Citroen will tell you the oil won't need changing. Citroen tell lies :lol: (tongue firmly in cheek)
x 2009
Unread post by Stickyfinger »
Get it......great cars..
If you can get an extended warranty that cover Steering-Rack, Struts and Pump. Lower front suspension joints are a weak spot but an easy change. Budget for a 3x Gearbox oil change.
Apply lots of thick waterproof (boat grade) grease to the rack pinion seal area)
Vehicle family C5 (X7)
AS/RP N° 11980 CJ 1 0008
Warranty Start Date 29/06/2010
OPB HBDA
BER e2*2001/116*0360*07
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5 (X7)
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL UPPER LOW PLUS
ENGINE DIESEL TURBO DW10BTED4 FAP
TRANSMISSION 6-SPEED AUTOMATIC GEARBOX
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR KPS - ABYSSE BLUE PAINT
INTERIOR TRIM TYPE LEATHER CLAUDIA MATINAL L019 "XT"
UPHOLSTERY COLOUR "FC"
GEARBOX (CHARACTERISTICS) BVA AM6C1
ENGINE (TYPE) EW/DW
OTHER BADGE, " MISC. " EXCLUSIVE
BADGE C5
Vehicle characteristics
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE W/O TACHO TORQUE
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) ANTI DEPOLLUTION L5 (ENGINE)
EXHAUST LONGITUDINAL REAR SILENCER
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
CATALYTIC CONVERTER CATALYTIC CONVERTER LESS THAN 10PPM
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) POWER 100 KW 320 NM
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION L5 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER PARTICLE FILTER
FAN 1 ELECTRONIC FAN INTEGRAL CTRL 160W
INJECTION ASSOCIATED VARIANT MOUNTING DELPHI
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITHOUT STOP AND START
Gearbox Transmission
FINAL DRIVE RATIO CP 15 X 53
WHEEL STYLE WHEEL BALTIQUE 17 INCH
CLUTCH WITHOUT CLUTCH
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 86
RIM/TYRE SIZE 17 INCH TYRE FITMENT
TYRE (SIZE, TYPE) TYRE 225/55 R17 97W NON-REINFORCED
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR TYRE DEFLECTION INDICATOR
GEARBOX TYPE Auto gearbox AM6
Suspension-Steering-Brakes
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 21
FRONT ANTI-ROLL BAR FRONT ANTI ROLL BAR DIAM 24,5
STEERING TRAVEL 180 STEERING MECHANISM TRAVEL
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION ACTIVE SUSPENSION MANUAL ADJUSTMENT
SUSPENSION (ARCHITECTURE TYPE) HYDRAULIC SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC STEERING
Body fittings
SIDE MOULDINGS (TYPE) CHROME SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION) PLASTIC + CHROME SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE) WHEEL TRIM BALTIQUE 17 INCH
EXHAUST TAILPIPE NON CHROME PLATED EXHAUST TAIL PIPE
SILL ILLUMINATION LAMP SILL LIGHT FRONT AND REAR
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRICMEMORY FOLDING EXT REAR VIEW MIRROR
WINDSCREEN WIPER FRONT WIPER AUTO SPEED 16 SPEED
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COL BUMPER + CHROME PROT + CHROME GRILLE TRIM
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR REAR VIEW MIRROR (GLASS APPEARANCE) TINTED EXT REAR VIEW MIRROR
EXTERIOR ACCESSORIES CHROME EFFECT EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CONVEX EXTERIOR MIRROR GLASS
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
GLASS (APPEARANCE) DEEP TINTED WINDOW
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
Interior fittings
ANTI-THEFT ALARM ALARM ULTRASONIC+PERIMETER STD
REAR SEAT ARMREST WITH REAR ARMREST
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION MPH
DRIVING POSITION RIGHT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT PALEA METAL DECOR
MISC. INT. LAMPS AMBIENT LIGHTING
LOAD SPACE TRIM CARPET+MOULDING AND CHROMED HANDLE
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 260 KM/H 160 M/H COLOUR MATRIX
DOOR TRIM SOFT ANODISED DECOR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT REAR ADJUSTMENT SPACER
DRIVER SEAT CONTROL MEMORY CTRL DRIVERS FRONT SEAT
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT ELEC CNTRL
FRONT SEAT ARMREST (OPERATION) FRONT ARMREST MANUAL
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS HALOGEN BULB
REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
DISPLAY DISPLAY DG4
COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
HEATING ELEMENT HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING FRONT PASSENGER AND REAR FOOTWELL ILLUMINATION
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
RADIO RECEIVER 4TH GENERATION "NG4" RADIO NAVE SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
DRIVER’S SEAT HEIGHT CONTROL ELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRROR ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
AIR CON./TEMPERATURE REGULATION AUTOMATIC AIR CONDITIONNED BI-ZONE
LOAD SPACE STORAGE W/O BOOT TIDY
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM REAR RADAR OBSTACLE SENSOR
LATERAL BLINDS SIDE BLINDS
TRIM ADAPTATION LEATHER GEAR LEVER KNOB + LEATHER GAITER
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL 4 BRANCH LEATHER STEER WHEEL DECOR METAL
SEAT LUMBAR SUPPORT (OPERATION) AUTOMATIC LUMBAR SUPPORT
AUDIO PACK AUXILIARY SOCKET 1 AUDIO RCA SOCKET
TELEMATIC UNIT WITHOUT TELEMATIC UNIT
Electrical
ALTERNATOR ALTERNATOR CLASS 18 180 AMP
BATTERY BATTERY L3 450
STARTER MOTOR STARTER MOTOR CLASS 6+
SPECIAL LIGHTING AUTOMATIC LIGHTING + FRONT DAYTIME LIGHTS
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
LABEL WITHOUT
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
x 3565
When did the 160 hp 2.0 HDi come in ? The one Nigel is looking at is a 138 - I thought they were all 160s by mid 2010 ??
Richard_C
(Donor 2026)
x 239
Unread post by Richard_C »
I had a C5X7 tourer for a long time, 2.0 163 manual steel sprung, regret selling it but wife has difficulty with getting in and out of low seats and she much prefers the C4 Pic we now have.
Around town, slightly awkward, needs big parking space. Not exactly agile. Out of town simply the best long distance cruiser I have owned. (SAAB 9-5 was close second). 700 mile days with 4 adults and full load, no problem.
Two things went wrong (on top of the usual tyre and brake replacements) in my 50k miles with it (had 20k on when I bought it and 70 when it went): front electric windows - lift wire known to rust. Window fails "closed" so can wait till another day to fix. An awkward but do-able diy job and you can buy the wires for very little (£10 or so), plus the rear high level brake light but I found you can open up the unit and bypass a corrosion-prone terminal with a wire and spot of solder. Took a while but not too challenging.
Plus to my mind they look really good from almost any angle, I never came back to it in a car park thinking "I'd rather have the BMWmercedesAudi parked next to it"
Richard_C
EDC5
x 130
Unread post by EDC5 »
As a fairly recent new owner of a '58' Auto X7, 138ps to be exact (57k miles on the clock when I got it) I'd second the gearbox oil change suggestion as mine was jet black when I changed it.
So far the only mechanical failure was a front suspension strut that I replaced myself, the part was ~£200, probably triple that to have a garage do it.
I haven't got the balls to inspect my steering rack yet :( . With the age of my X7 if its going to leak then it would have done by now I suspect.
How does the gearbox feel when changing gears? any clunks or delays? any rev flaring (sign of worn valve block).
Apart from that as long a the suspension goes up and down well then it should be fine.
x 2009
Also, inspect the rear suspension pipes, roll bar and sphere block ....the only parts NOT protected by any anti-rust coatings. It is easy to cover it all it wax to protect it. The roll bar powder coating "splinters" as it enters the bush, clean it off, paint and wax it. All easy to do in a hour.
crapday69
(Donor 2017)
x 59
Unread post by crapday69 »
Richard_C wrote: 16 Nov 2017, 17:58 Plus to my mind they look really good from almost any angle, I never came back to it in a car park thinking "I'd rather have the BMWmercedesAudi parked next to it"
I agree its the best looking tourer out there. If I had the money, i'd go with the top of the range V6, but my 1.6 eHDI will do for now. I was nearly crying when they wrote it off as they are hard to get, especially up here in Scotland. Luckily it was only cosmetic damage and the bodyshop is fixing it, should be ready today.
x 2938
I noted the LMC dealer name, that's the original supplier of the one I found in a field, I'm going to email them and see if they have some early history for it, what do you think the chances are?
Richard_C
(Donor 2026)
x 239
crapday69 wrote: 17 Nov 2017, 06:39 I agree its the best looking tourer out there.
Picnic stop on Autoroute Blanche, just to remind myself ... bit off topic I know but its Friday.
Richard_C
x 25
well thanks everyone but family constraints got in the way again but I did manage to get some time away
last Saturday to go have a break from family worries and see some friends I haven't seen for 8 years in Portsmouth,.
I am so impressed with my Mk2 diesel hatch Ive decided to keep her, so sorry to waste your time everyone.
Im pondering now about clutches SMF or DMF as there is very little difference in price £5 more for the DMF.
and I am going to have the gear selection automated electronically, basically the car will be able to be driven manually or using a
semi auto gear change the pedal will travel in and out at the press of a button on the gear lever and I will still need to select the gears.
I did 330 miles last Saturday and it cost me £41.00 to fill up when I got home.
That's not to bad at all. and I was carrying four passengers around Portsmouth in the afternoon and gunning it on the way home
up the A34 at about 75. correct me if Im wrong but I make it about 42 to the gallon at £5.175 per gallon. £1.15 a litre. 7.9 gallons.
regards.
Nigel.
