Mixing gearbox oil.
milleplod
x 15
Mixing gearbox oil.
Unread post by milleplod »
I've just had 3 ltrs of fresh oil put in my '09 C5's gearbox, courtesy of Malcolm at Savoy Garage - its really made a difference to the low-speed changes, they're much smoother now. I'd already bought the oil from Smith and Allen, the JWS3309 stuff, and there's now 2 ltrs left in the container. I've just called at a mate's for a brew and was telling him about the fluid change - he's got 5 ltrs of ECP's Triple QX Multi Vehicle ATF-U that he's offered me for £15. Looking at the blurb on it, it has JWS3309 in its spec list. Would there be any harm in using this for the next 3 ltr change do you think? Or should I stick to the same brand?
Mind you, thinking about it, the S&A stuff seems to have mixed nicely with the black gunge that's been in the box from new, so perhaps I'm overthinking things! :lol:
Pete
Nocto Diuque Venamur.
Sloppysod
x 396
Re: Mixing gearbox oil.
Unread post by Sloppysod »
Providing it meets the same specification then mixing should not be a problem. Personally, I would Google both oils and compare the data sheets, and not rely on the information on the bottle, just to make sure. The JWS3309 is a Toyota spec and is available online.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
EDC5
x 130
Unread post by EDC5 »
Is there any point risking it when the proper stuff is £13 a litre:
https://www.ebay.co.uk/itm/Mobil-ATF-33 ... SwZElZmRno
van ordinaire
(Donor 2017)
x 400
I found that S & A was one of the very few suppliers of the correct spec. oil, when I was gently put right about the correct weight oil to use - AND a little under £20 for 5 litres. Somewhat curiously, few, if any, of their other products are so keenly priced.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
wurlycorner
x 271
Unread post by wurlycorner »
EDC5 wrote: 20 Nov 2017, 11:07 Is there any point risking it when the proper stuff is £13 a litre:
£11.95 from opie (plus £3.50 delivery but then minus discount of 10% if you use code LUDEGEN )
https://www.opieoils.co.uk/p-69402-mobi ... fluid.aspx
Just noticed they also do 5Litre packs of LHM for less than available on ebay, too (hadn't noticed them on their store last time I checked);
https://www.opieoils.co.uk/p-131828-trw ... fluid.aspx
Iain
CX DTR T2 Safari (silver)
