swapping myway with emyway
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
crapday69
(Donor 2017)
x 59
Unread post by crapday69 »
Can you just swap the head units or is there a bit more involved to upgrading. Just thought i'd ask before I start looking at citroens that are breaking on ebay.
Gary.
EDC5
x 131
Re: swapping myway with emyway
Unread post by EDC5 »
I believe you also need to swap the screen for a high resolution screen. The cable can stay. Additionally the high-res screen is a slightly different size so doesn't fit in the existing fascia so the correct one needs to be found.
crapday69
(Donor 2017)
x 59
So i'd need to find a breaker. I've tried that for a front osf wing with no luck.
EDC5
x 131
Yep, I upgraded to a MyWay from the normal radio.
I was unlikely to ever find the high res screen and fascia in the UK so I gave up.
