C5 mk3 electric front window regulator replacement.
crapday69
(Donor 2017)
x 59
Unread post by crapday69 »
When my window jammed open due to a frayed cable I had to do a repair. I bought a few repair kits, but they where murder to fix, a few cut and jagged fingers later I just bought the whole regulator from ebay for under £60. It came from France and was a bargain. I see them under £50 now
https://www.ebay.co.uk/sch/i.html?_from ... r&_sacat=0
You can follow the clear instructions here as I did and its very easy. It should take you less than an hour if you buy the complete regulator.
http://www.instructables.com/id/Repairi ... ic-Window/
I hope this help someone as it did me. I want to try and help if I can, its only fair to give a little back.
Gary.
PS I really advise just spending the extra on the regulator rather than the repair kit, it does make life a lot easier.
osx
(Donor 2022)
x 15
Re: C5 mk3 electric front window regulator replacement.
Unread post by osx »
Replaced it today. Took a couple of hours but didn't break anything ;).
Removing and refiting the speaker was a pain. Not sure why Citroen decided to use rivets.
C5 X7 Exclusive 2.0 HDi Auto
x 5692
osx wrote: 28 Apr 2018, 19:41 Not sure why Citroen decided to use rivets.
Because they are frogs!
Oh, is that my coat? How kind.
