Citroen c5 x7 front break pad sensor
goggi10
Unread post by goggi10 »
Helo my frends o have one question. I have Citroen c5 x7 2012 BL562351 and i went to change front break pada and mz dealer said that in my car is missing installation for sensors for break pad is that possible that my car doesnt have that instalation and if can somone send mi the diagram and part number of that instalation thanks.
x 6945
Re: Citroen c5 x7 front break pad sensor
The Brake pad wear harness is available as a separate part (number 12 in the diagram). It is likely that the harness has either been snipped off or removed by somebody as according to your VIN, the harness was fitted to your vehicle.
It is part number 4433 03 and in the UK costs £17.69 (Excluding VAT)
x 3565
On my C5 the connectors for the front brake pad sensors are only fitted on the left hand side of the car. I think the genuine Citroen replacement pads come with enough leads (number 12 in picture above) to connect up both left and right sides of the cars, but these pads are used in a lot of different models of cars (Peugeot, Citroen and others) and some of them will have connectors on both sides of the car. Check both sides of your car to see if there are two small connectors to plug in the leads as they may only be present on one side.
x 6945
Yes, I've checked on the wiring diagrams and 'goggi10' only has a left hand brake wear indicator. I suspect this is because he has the manual handbrake with standard metallic suspension.
My car has it on both sides as denoted by the wiring diagram:
goggi10
Thanks guys but i cant locate the jack where i can plug wire from pad. Can you send me a picture were is it
x 6945
Here you go:
From the other side:
x 3565
This is taken from my 2009 C5. The photo is taken from in front of and above the front left hand wheel / suspension. The two white connectors are the warning wires - they are one end of item 12 in the previous parts diagram Givemeabreak posted up. They might be missing on yours, or they might be a different colour. If the 2 hole black rubber socket that they push into isn't attached to your car then you probably haven't got the brake warning wiring fitted.
Brake warning wires - own work
goggi10
Hi all thanks a lot but deffinitly i dont have break sensors and i cant belive because car have alm9st evrything. My goddamm fiat bravo 2009 had break sensor just unbelivible.
x 6945
Your car did have the sensor according to your VIN but ONLY on the left hand side. So check in the picture Bobins posted for the harness somewher. Again, maybe the previous owner didn’t respect the warning system and cut it! The replacement leads won’t be any good without the harness to plug into though.
goggi10
Again thanks guyes definitly somonecut it off. Do you maybe know the part number of the cable so i can replace it. Thx
x 6945
The part number is 4433 03
x 2938
It seems a strange idea to me that they'd build a car without pad wear sensors on all the front pads but maybe they know something we don't. :-D
I know that Renault used to supply brake pads that were 'handed' i.e. they were marked to be fitted to the left or right side of the vehicle, Trafics were notable for this.
xf1ref
x 12
Unread post by xf1ref »
GiveMeABreak wrote: 28 Oct 2017, 12:32 The Brake pad wear harness is available as a separate part (number 12 in the diagram). It is likely that the harness has either been snipped off or removed by somebody as according to your VIN, the harness was fitted to your vehicle.
Hi Marc,
What torx head I need to remove the fixed part of the caliper? screw 7 from the diagram.
I did not want to open a new topic only for this.
x 6945
The bolt is a 12 X 150 -30, so I suspect a T30
xf1ref
x 12
I have torx T55 since the time I changed the rotors at Xantia. Today I've checked at C5 and it is the same.
