bx rear susp arms
moizeau
x 423
bx rear susp arms
Unread post by moizeau »
I fitted the refurb kit to the lh rear trailing arm due to excessive play and camber about 2 years ago. What I didn't know was that there is a pre-load shim. So I still have the poor camber and it's causing abnormal wear on the tyre. Having since read a lot of articles on doing the job, I haven't found any info on how you select the correct shim? Is it a case of measuring or do you just start at the largest, going smaller until you can get one to fit?
The car's just gone through the CT, so it's worth doing.
On a by the way - does everyone living in France know the CT is coming into line with the rest of Europe from May next year, including a plug in to a diagnostic if it's 2007 or newer, also any welding will need to be done by a body shop, with the bill available as proof. No DIY welding allowed
Thanks in advance
Pete
x 1746
Re: bx rear susp arms
Hi Moizeau
I did this job on a BX years ago. Hardest work was drifting out the old bearings, without the special tools. Did it all the same.
If you have a copy, look at the Haynes BX Manual (908), p.235-7 (section 9 - rear suspension arm).
It says there that changing/replacing the spacer (shim) is only necessary if the suspension arm is being renewed, and the free play needs to be adjusted. I guess the factory selected the right shim for the arm.
I just replaced the bearings (Citroen parts), and all was well thereafter.
If you need these Haynes pages scanned and posted, just shout.
x 1995
Unread post by Stickyfinger »
moizeau wrote: 20 Oct 2017, 18:34 On a by the way - does everyone living in France know the CT is coming into line with the rest of Europe from May next year, including a plug in to a diagnostic if it's 2007 or newer, also any welding will need to be done by a body shop, with the bill available as proof. No DIY welding allowed
Thanks in advance
Geeze, how Fing stupid....so a qualified welder in Aero Space cannot weld his own car ? .....ridiculous.
citroenguy
(Donor 2021)
x 77
Unread post by citroenguy »
I found something in my small cache of Citroën files..
This is the rear suspension part of the factory BX workshop manual (in Swedish ofcourse :-D )
Noteworthy translations:
Axial play in the conical bearings on the suspension arms 0,17 to 0,30 mm
Adjustment shims, suspension arms 0,15 to 0,95 mm
"The adjustment shim is placed on the outer side of the suspension arm"
See page 8 to 10 for the adjustment method, they are using special tools ofcourse.
I hope the linky works
https://files.acrobat.com/a/preview/7af ... 167a68b22f
/Mikael
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
x 2938
Stickyfinger wrote: 20 Oct 2017, 20:01
Thanks in advance
Likewise here, a qualified mechanic with fifty years experience has to take his car to the eighteen year old 'who's done the course' to get it certified as roadworthy. :(
x 1995
So you know all the ways of covering up shoddy workmanship then and how to pull the wool over the 18 year olds eyes :)
x 1240
Unread post by Peter.N. »
I have done a number of trailing bearing replacements on BX, CX, XM and C5 and never had a problem, if the angle of the arm is sufficient to cause tyre wear I would think that either the new bearing has failed or the arm was worn internally allowing the bearing to move. I always pack the space between the two bearings with grease on reassembly, I think the shim is a red herring, or maybe silver metal. :wink:
x 2938
Stickyfinger wrote: 21 Oct 2017, 09:59 So you know all the ways of covering up shoddy workmanship then and how to pull the wool over the 18 year olds eyes :)
:) Not my style Alasdair, I like things right, that way there are no comebacks.
x 1995
Just pulling it mate :)
moizeau
x 423
Thanks for all that, this was a SKF bearing kit, I read that the shim (as mentioned is on the outer side) should stay with the car. I didn't see one. Either it was well chewed or fell on the grass. The trailing arm was well packed with grease and looked in good condition with no obvious wear. Apparently it's the same procedure with the Xantai and the assorted shims can bought from Cit? I read that that it is there to 'pre-load- the taper rollers before the through bolt is tightened. But how do you judge what size goes in?
Thanks again
Thanks for the workshop manual pics, just one question, what is being measured? The arm with the bearings fitted and the gap where it goes in the chassis?
Pete
citroenguy
(Donor 2021)
x 77
I seems that they are measuring the arm with bearings and seals (?) fitted with the special tool, compared to the length of the bearing shaft,
x 1490
Allegedly the shim set is still available, part number 514327 - same is listed for the Xantia and C5. Can't get a price as service.citroen is playing up.
I'm sure I read somewhere that in the absence of the proper tools, you can set the pre-load close enough by selecting a shim that just allows the arm to drop under its own weight.
x 1746
...Presumably just to eliminate any end-float, and then lightly load the bearings. Doesn't sound amiss.
moizeau
x 423
That would make sense Richard, similar principle to Landrover wheel bearings and the shim is to centralise the four halves of the two tapered bearings because it can't be done just using the nut (like a wheel bearing because the arm is 'suspended in the carrier. It will be interesting to see how easy it is to squeeze a shim in with the limited access.
I read somewhere that the shims come in a packet of varying sizes to give you a choice. Just need to track some down.
I thought they may be measuring the arm with bearings and seals, then measuring the gap in the carrier?
Thanks again
Pete
x 1746
As Richard says, listed as still available "shim set"', 22x30mm
Same part for C15, BX, XM, Xan, C5.
