Problem with my Opel Omega
tomiwa
I have an OPEL OMEGA B 2.5ltrs V6, 1996 model. I found thick whitish colour emulsion in my radiator bottle, this appeared to be a mixture of oil and coolant. I notice my car overheats in traffic jams and when my AC is on. I also found out that both water level and oil level keep going down each time I checked them. I discovered as well that when I switch on the AC, the green coolant drains out profusely around the Oil filter area. Can anyone tell me what to do to solve these problems
James.UK
philhoward
wontoby
If the head gasket was the problem, then there will be some water in the oil, seen on the dip stick. Maybe the problem is likely the oil cooler, somewhere around the oil filter housing. Maybe your car is one of those that has a sheet metal oil cooler mounted on the oil filter extension housing just forward of the oil filter. It should have two water lines attached. These have a history of developing leaks - it may simply need to be replaced.
I'm not an Opel expert but I have read these in some forums.
Jon
