Lambda Sensors
Eddie Nuff
New User
x 38
Lambda Sensors
Unread post by Eddie Nuff »
Are lambda sensors interchangeable? The reason I ask is I've dropped on yet another C4GP 1.6hdi with knackered turbo, egr and dpf. The woman who owned it insisted it didn't need servicing because it hadn't done 20k miles since its last service. That was nearly three years ago :shock:
I have all the replacement parts except for the lambda sensor. The proper one is 1628LS at £98 from Citroen and about £85 elsewhere. I have seen 1628KN and CW at a third of the price but don't want to waste money on a sensor that doesn't fit or is rejected, hence my question.
x 6956
Re: Lambda Sensors
1628 LS is actually a bracket.
1628 CW is a Bosch 4 wire sensor
1628 KN is different - looks like a kit and says needs additional work. Plus the connectors look completely different.
Eddie Nuff
New User
x 38
Curious! All three came up as sensors on my search, but that's by the bye. Question's still the same though, irrespective of part numbers, are they interchangeable?
Anyone?
x 1938
Re: Lambda Sensors
Unread post by Paul-R »
Speaking generally you can buy multi-application Lambda sensors which require you to cut the plug off the old sensor. Sometimes this is the only difference between different sensors so they should work. Having said that on the only occasion I've had to do with Lambda sensors I bought the right items.
x 6956
Re: Lambda Sensors
I've seen quite a few variations - some with 5 wires others 4, different materials and different operating voltages and signalling - so personally I would stick to an original designed for that specific engine and ECU. IF there were all the same functionally / operationally wise, surely there would only be the one type.
Some explanations / debate here:
https://www.pistonheads.com/gassing/topic.asp?t=1201498
x 1485
Re: Lambda Sensors
If it's a 16v then there isn't a Lambda sensor ( no need on a diesel as it runs lean all the time). I think the 8V engine may have a Lambda, possibly to help optimise the re-gen cycle. In a 16V the sensor halfway down the CAT / DPF is a temperature probe.
Eddie Nuff
New User
x 38
GiveMeABreak wrote: 11 Oct 2017, 12:02IF there were all the same functionally / operationally wise, surely there would only be the one type.
This is the argument I'm having with myself.
Okay the difference is only £60 or so but better the right one than the the wrong one.
(but £60 is still £60 :wink: )
x 6956
Re: Lambda Sensors
I know - and there's always the faffing about returning it if wrong and all that hassle and wasted time Neil. :wink:
dnsey
x 19
Re: Lambda Sensors
Unread post by dnsey »
Essentially, there are two main common types of lambda sensor, titanium and zirconium based. Of these, there are standard and pre-heated versions. Somewhat rare is another type which gives a continuously variable output. Beyond that, the main difference is in connectors, although there are also variations in construction. Bottom line is that there are usually cheaper universal equivalents to an OEM sensor. Cheap ones often don't last long, but the appropriate Bosch, NGK, Denso etc. universal types, where the original connector is re-used, should be fine.
x 1485
Re: Lambda Sensors
All interesting stuff about Lambada sensors - Mandrake had trouble with a V6 where he fitted an apparent correct sensor, but it was the wrong resistance, and never worked properly - however, the sensor in question here is not a Lambda sensor I am sure. Eddie posted 1628LS at £98, but the temperature sensor fitted to 1.6 16v HDI is 1618LS at the right price, so that is the bit he is looking for. I doubt it's knackered TBH, and can probably be refitted to the new DPF.
