Nothing better to do tomorrow......
milleplod
x 15
Unread post by milleplod »
.....so I thought I'd take the opportunity to break a few of the tailgate inner trim panel clips! :-D The high-level brake light stopped working ages ago (snapped wire) and the rear washer pipe's broken too - time to sort them out, methinks! :)
Anyway, can anyone tell me which trim clips I'll need should (when!) I break a few - eBay is awash with multiple types. :? Looking at this 'how to' - http://s796.photobucket.com/user/nevcco ... t=3&page=1 its the upper trim panel I'll be removing.
Pete
Nocto Diuque Venamur.
x 1955
Re: Nothing better to do tomorrow......
Unread post by Paul-R »
The Photobucket site is not good for hosting any more. Can you upload the photo to the forum directly?
milleplod
x 15
Paul-R wrote: 08 Oct 2017, 21:15 The Photobucket site is not good for hosting any more. Can you upload the photo to the forum directly?
Doesn't clicking on the link take you straight to the photos? :?
Pete
x 3565
The link takes you to the photos, but the trim clips aren't obvious.
milleplod
x 15
bobins wrote: 08 Oct 2017, 21:26 The link takes you to the photos, but the trim clips aren't obvious.
I know, I was just showing people the trim panel I was going to remove! :)
Pete
x 3565
Which ones are you planning on breaking ? :-D The tailgate parts list is a little extensive to post up as it is, so shout what the numbers are and we'll look up the part numbers :)
BTW, part 80 is 9341PF should that be the right one :-D
Tailgate parts
Tailgate parts
milleplod
x 15
Crikey, that's an eyefull!! :shock: I think I'll be removing trim panel no. 30, so yes, looks like clip no. 80 is the ones I'll be breaking! :lol:
Pete
x 3565
There's 19 in total - you get extra points if you break all 19 of them :lol:
milleplod
x 15
£2.50 for 10 on eBay - bring on the breakages! :lol:
x 1955
milleplod wrote: 08 Oct 2017, 21:18Doesn't clicking on the link take you straight to the photos?
Pete
No, it takes me to a page trying to sell me a service for $300 a year!
x 5690
Paul-R wrote: 08 Oct 2017, 22:15
Pete
Works OK for me!
milleplod
x 15
myglaren wrote: 08 Oct 2017, 22:47
Pete
Works OK for me!
Me too. Mind you, Ive never had anything to do with Photobucket.
Pete
Richard_C
(Donor 2026)
x 239
Unread post by Richard_C »
Moving on from the clips issue to the brake light. This might help you or others.
My C5 (no longer have it) had a failed light and after much prodding and testing it wasn't the normal break in the wire near the join. I got it all out, not too difficult but take care not to scratch the spoiler - if I reacall it flops down onto the roof so I put a rug across. Once out I applied volts straight to the unit but no success. I separated the lens from the body by running a blade around it - came off easily. The circuit board with the LEDS on it sits on two pillars which you can't see, but if you gently ease the board up progressively from each end using a screwdriver you see how it fits together and in my case the amount of corrosion. You can test the LEDS by applying 12v to the board, remember polarity because they only work one way. After much cleaning and scraping without much success I ended up soldering a new wire directly onto the circuit board, drilling the side of the housing and running the wire all the way back to a connection way down the harness. A bit of sealant to seal hole and stick lens back on and all was (reliably) well.
OK, an hour or so of messing about but I think a new brake lamp is fairly expensive.
Back to clips. I broke a couple, missed one in the clearout and every time I opened the tailgate after that it rattled as it ran down some hidden channel. Grrr. Think like a surgeon, count the bits before you sew the body up.
Richard_C
milleplod
x 15
Richard_C wrote: 11 Oct 2017, 18:04 Moving on from the clips issue to the brake light. This might help you or others.
I can see my broken wire, but your info could come in handy in the future! As a matter of interest, how exactly did you manage to get the plastic trim panels off??!! :? I spent ages the other day levering and pulling in various places, but got nowhere - it felt as if either the plastics would break, or my fingers would! :shock:
Pete
Lenny
x 63
Unread post by Lenny »
The last time I took all the trim off my tailgate I used a smallish hole saw on the top bit and drilled a couple holes where the spoiler locating screws are hidden. The holes are covered with rubber blanking grommets and are hardly noticeable.
Next time I have to whip the spoiler off it'll take two minutes and I'll break no clips in the process.
(The worst bit as I recall it was getting the four 'orrible sodding screws back in at the bottom edge)
