I have a 1995 106 Roland Garros which I converted to diesel. The engine I fitted was a 1.4 non turbo from a 1884 106 Kid Diesel. The Roland Garros has a rev counter fitted which seems to be connected to the engine management ECU but the kid diesel has no engine management ECU and according to the wiring diagram in the Haynes manual is connected direct to the TDC sensor. The conversion was successful but the rev counter doesn't work, didn't expect it to. I asked at the Peugeot dealer and the diesel rev counter is no longer available, last price listed was about £300 so didn't bother.
I recently found a NOS rev counter on ebay for £30 which is listed as suitable for a 106 Mk 1 diesel so I brought and fitted it but it doesn't work. I'm using the TDC sensor from the Kid Diesel that didn't have a rev counter but I think the diesel with a rev counter has a different TDC sensor than the diesel without a rev counter. If this is the case and I have the wrong TDC sensor replacing it may cure the problem but I would appreciate some advice before I spend more money. There's no guarantee the sensor I have fitted is any good but I've no way to test it.
Finding a used one would be difficult as there aren't many in scrap yards these days and due to health and safety rules many yards will not let us wander round the yard and look as we used to.
When I changed the engine I disconnected the large multi connector by the battery, swapped the engine and connected to the replacement engine. Everything worked I just had to put a bulb in the glow plug light on the dash. I haven't tried to trace the wires from the rev counter to the TDC sensor as it looks like it will be a pain but I will if I have to.
Regards
Clyde
Peugeot 106 Mk1 Diesel Rev counter & sensor
clydeowenp
- x 19
doctle
- x 225
Re: Peugeot 106 Mk1 Diesel Rev counter & sensor
Have you considered an aftermarket rev counter on a dash pod? They usually connect to the alternator, you could replace the rev counter you have with a clock from a base petrol model?
Oh buggle
elma
- x 287
Rev counters can be wired into the alternator if all else fails, I did it that way on my old LDV van.
It wasn't difficult at all but the maths for the components took a little while to work out.
I say components as I think it was a few resistors but actually don't remember.
If you don't have any luck with the TDC I'm sure I could dig out the data I used to do mine.
PM me if you want me to, I rarely check non Xantia threads so may well miss if you ask here.
doctle
- x 225
elma wrote: 21 Sep 2017, 22:21 Rev counters can be wired into the alternator if all else fails, I did it that way on my old LDV van.
I have never done this kind of work on a French car, I have put a VW diesel engine into a MK2 golf petrol. Non turbo 1.6 diesel it didn't exactly set the world on fire!
Oh buggle
