I've noticed that whilst the bx has 2 rubber return pipes coming from the clamped rubber cup, the xantia has only one. My question is, can a xantia return hose be fitted to a bx? Obviously one of the inlets on the inner wing would need to be blocked off or a 'T' used. The reason is, at the local tat yard there used to be loads of bx's and when I was there I'd take any good ones. Now though, there are only a handful, but there are 10's of xantias.
Thanks in advance
bx front strut return pipe
Onlinemoizeau
- x 429
Pete
BX
- x 19
Re: bx front strut return pipe
On the bx one of the two allows the strut to suck in air into the bottom of the strut on the rebound. It goes back to the reservoir above the fluid level. There is a non return valve fitted to the air pipe at the reservoir. The other allows fluid that leaks by the strut hydraulics along with any excess air to return to the reservoir when the strut is compressed. A blockage on either line results in burst pipes. I don't know how the system works on the Xantia or the C5 which have only one pipe.
I guess but don't really know that a tee piece would be the best way to use a single pipe on the BX. To use the double pipe on the xantia , just plug the unused pipe.
