I've just purchased a 307cc 2.0 hdi 136 which doesn't seem to be boosting. I've got a fuel cap sensor, fuel level and pre heat faults coming up. Based in Sheffield, any help appreciated.
307 2.0 hdi
Nelly1
Re: 307 2.0 hdi
Have you checked the magnets on the fuel cap apparently they can come off so the sensor doesn't detect the cap.
- x 1485
Re: 307 2.0 hdi
None of those faults will stop the turbo - however, it could stop the regen of the DPF which might be causing a blockage. You need some better diagnostics with live data to see what is going on.
Fital
Re: 307 2.0 hdi
Swapped over the fuel cap and maf and car is boosting again, went through and took of front intercooler pipes checked and put back.
