2004 scenic boot wont open
citroen7
Unread post by citroen7 »
Looking foe help guidance divine intervention etc
The boot will not open on key fob oe push button i have checked switch for continuity and 12v across the lock gets it going i have also checked the wiring from body to tailgate but to no avail i had no rear fogs as well but ran a cable to a switch on the dash are these two problems related? everything else electrically is spot on . I am starting to tear my hair out as i need the boot working for my daughter going back to uni i have also tried a reset but nothing so any pointers?
x 3296
Re: 2004 scenic boot wont open
I think you might have a blown fuse. A friend had an issue with his van in that, after trying to use the screen wash during cold conditions) both the washer and the boot would not work. It turned out they shared the fuse, and when he changed it they started working again.
citroen7
double checked all the fuses thinking of taking a feed from the number plate lights to see if it will operate
