2006 diesel Berlingo van engine light
nginmu
Unread post by nginmu »
Hi, a friend bought a very cheap Berlingo diesel van at auction. I had to do a few bits on it - clutch cable, brake pads, new locks.. otherwise it's turned out to be a good vehicle.
Just one thing remaining he'd like to sort out - the engine warning light is constantly on.
I've connected a basic / 'standard' OBD reader to the OBD port; it connected fine but reported no faults. (Gendan Engine Check Pro IIRC)
With the vehicle ignition at position 1, the engine warning lamp is on, and the OBD reader reports it's on as well.
If I hit 'clear codes' on the reader, it reports success (even though there's nothing to clear) and the reader reports that the engine warning light is now switched off. However, it remains lit on the dash.
If I then start the engine, the reader continues to report 'warning light off', but the lamp on the dash does stay lit.
I'm guessing the cause of the warning is something inaccessible / citroen specific in one of the van's ecu's? whether engine ecu, brakes computer, airbag etc etc?
I'm wondering what software / series of button presses etc I need to troubleshoot this further. ISTR a while ago when I had a citroen dispatch van, I had to get some special software on a cd.. can't remember what it was called or how i connected it to the vehicle. I might be able to dig it out if it's helpful,,
Any ideas thoughts suggestions gratefully anticipated.. Thanks
x 3298
Re: 2006 diesel Berlingo van engine light
You will need to use a Diagbox/Lexia system, as only they will communicate properly with the various ECUs. Unless they are very expensive professional OBD readers generic readers do not 'understand' the PSA vehicles.
There are forum members who have Lexia clones, and are willing to help out. Here is the list;
viewtopic.php?f=19&t=56452
nginmu
Thanks for your help :-)
I found my old CD which I had for my old 2004 Dispatch. It's labelled...
LEXIA 3 v 45
Cable: ACTIA PSA EVOLUTION XS INTERFACE ETC.
OLDER VEHICLES REQUIRE 30 PIN PLUG
IIRC I never actually used this software. Would it be suitable for the Berlingo?
Where could I get the right cable, or maybe specs to build a suitable cable? Is it just a plain although proprietary cable, or is it like the generic USB OBD adapters, with a box of chips included in the middle of the cable?
I'm ok with electronics assembly & basic programming but if it involves much more than a solder-by-numbers job & maybe programming a microcontroller with precompiled code, I'd deffo be better either obtaining a pre-made interface or seeking the help of someone who already has suitable hardware..
[edit] on further reading, I guess I need "a lexia" or "a diagbox".. maybe something like eBay item number: 122586086176 ?
