2.0Hdi EGR valve failure
centurus2400
x 4
Unread post by centurus2400 »
My C5 X7 is coming up to 70,000 miles and the engine, whilst in my ownership, has always run impeccably.
However, over the last few months I noticed an occasional slight hesitation and lack of throttle response when accelerating.
A few weeks ago it started fine from cold but then had minute or two of missing, and reluctance to rev, which then suddenly cleared and it was back to normal.
It then ran perfectly so I made the unwise decision to defer a visit to my excellent local garage.
This of course came back to bite me in the bum, as last week it stalled in the middle of the road junction outside my house and absolutely refused to start, though it cranked over fine.
Also, it came up for the first time with the dreaded 'depollution system fault' message. At this stage I'd have welcomed even limp home mode, but still no joy, so out came the lads from the garage and it was towed into their workshop-fortunately only a mile away.
Of course next day, it started and perfectly again....
They put it on the code reader and found fault codes relating to the injectors and the EGR valve. The injector codes cleared straight away but the EGR one didn't, so a new Delphi EGR valve was ordered and fitted.
It appears that the EGR valve was intermittently sticking fully open and preventing the engine from running.
It's all fine now though, so if anyone suffers from similar symptoms on their car don't leave it too long or you may well find yourself going nowhere fast :shock:
EDC5
x 130
Re: 2.0Hdi EGR valve failure
Unread post by EDC5 »
That's interesting, I've always been suspicious of EGR systems. At the very least when they fail they should fail closed and not open!
jgra1
(Donor 2021)
x 37
Unread post by jgra1 »
hmm..
what engine HP is that Cent?
centurus2400
x 4
It's the 138 hp version.
Delphi fuel system, and so it would seem, a Delphi EGR valve.
The mechanic reckoned that all EGR valves give trouble sooner or later, but that the 2 litre Hdi was one of the more reliable ones!
xf1ref
x 12
Unread post by xf1ref »
I have the 163 hp version, RHH engine, and I know that the egr valve is different that the one on 138 hp engine. Also I have from time to time some kind of slight hesitation but only for some seconds when the engine is cold. I read on other forums that the electronic part is the problem and also the mechanical part because is becoming sticky, but I wonder ..if the vacum controlled egr can be cleaned also an electronic egr can be cleaned ? Is someone who tried to clean/repair the egr valve?
EDC5
x 130
the 2.0 138 RHR also has an electronically controlled EGR. I believe a stepper motor is used to more accurately open or close the valve. If you suspect the EGR is at fault and staying open, maybe you could block it temporarily and see if the problem is cured?
I don't think disconnecting it would work as the flap may be mechanically jammed with soot.
jgra1
(Donor 2021)
x 37
x1 - I have one on the bench .. I may take a look at it..not sure... it's sitting there doing very little at the moment
EDC5
x 130
jgra1 wrote: 11 Sep 2017, 22:40 x1 - I have one on the bench .. I may take a look at it..not sure... it's sitting there doing very little at the moment
The EGR valve?
jgra1
(Donor 2021)
x 37
yes.from a 163
xf1ref
x 12
Nice Jgra1, maybe when you will have some time to have a look at the valve. I found a movie on youtube where is shown the sticky valve from RHR engine and I suppose if the stepper engine and electronics are ok the mechanical part can be cleaned.
Reason: YouTube tags
fcesur77
x 3
Unread post by fcesur77 »
Hello everyone, I own a 163HP version of C5 2.0. I used to get a DPF fault on the screen and I cleaned it up through a machine. After that started to get EGR valve malfunction. I do not see EGR valve fault on the screen for a month. The car recently started to act like stalling and jerky below 2000 rpm and as far as I know, EGR valve is mostly open around this rpm. My question is how can I take off the EGR valve to clean it up physically. It is not easy to reach this part and work on the restricted area because it is behind of the engine. I know chemical cleaners will not work at all.
Sloppysod
x 392
Unread post by Sloppysod »
fcesur77 wrote: 21 Jan 2026, 15:31 Hello everyone, I own a 163HP version of C5 2.0. I used to get a DPF fault on the screen and I cleaned it up through a machine. After that started to get EGR valve malfunction. I do not see EGR valve fault on the screen for a month. The car recently started to act like stalling and jerky below 2000 rpm and as far as I know, EGR valve is mostly open around this rpm. My question is how can I take off the EGR valve to clean it up physically. It is not easy to reach this part and work on the restricted area because it is behind of the engine. I know chemical cleaners will not work at all.
After you have cleaned the EGR valve, have a look at the filter, it may need a new bit of foam as the disintegrate of time or miles.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
