The old girl of 22yrs ... 1995 TD Xantia, '2.7.3 shock absorber has a a serious fluid leak offside rear'.
Am i right in thinking that this may be just a leak off pipe as the suspension is going up and down aok? Or could it be more serious?
Whats more worrying is that they'd not seen a xantia in years and didnt have the expertise to fix any problems yet they did feel up for testing (and failing) it .. shame really! Or should that be shameful.
Mot failure ...
superloopy
- x 19
Mot failure ...
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
Eddie Nuff
- New User
- x 38
I always stay whilst mine are being tested and if there are any problems they always show me what they have found, but as I've been taking my cars to the same MOT station for the past 25 years, and they don't do repairs, we know each other well enough by now.
In fact I'll be paying a visit next week . . .
- x 8272
Re: Mot failure ...
Is it leaking around the sphere Mike?
It may be a bit of corrosion on the top of the suspension cylinder... A Dowty Washer will fix it... There's been posts about it in the past...
- x 1751
Re: Mot failure ...
Agree - First port of call is leak-off pipe, or a split boot.
Pretty good for a car not fitted with "shock absorbers"!
superloopy
- x 19
Re: Mot failure ...
Cheers Jim. I've posted a request on FS & WTD in case anyone has a few spares lying around
Mike
- x 1240
Re: Mot failure ...
If it's the leak off pipe you can usually repair it in situ, put the car on high suspension and turn the steering until you can see it, if it's adrift or leaking, snip the last inch off and refit it, just pushes on. At least this certainly applied to the XM.
- x 1751
Re: Mot failure ...
Rear, but similar applies - pipework and boot easily accessible with back end on ramps - on XM anyway.
Boot split: clean up thoroughly with alcohol, and then superglue the split.
superloopy
- x 19
Re: Mot failure ...
Cheers.
Fixed it today, boot had split, not quite perished yet but i think a new boot is needed soon. How hard a job is that? More worryingly my nsr sill has a hole that will accomodate my fist after the tester had done his stuff. It's not just the outer either. The whole back section including inner sill needs looking at. Is the inner sill repairable? I've had the outer patched a couple of times in recent years. Rest of the car is fine.
Mike
lexi
- x 134
Re: Mot failure ...
Could be time to sell and get a cheap C5, while they are still around. Once you start chasing with the welder.....
Try this stuff for split rubbers. Top drawer. http://www.ebay.co.uk/itm/STORMSURE-5g- ... 2749.l2649
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
superloopy
- x 19
Re: Mot failure ...
Cheers Lexi.... i've ordered up a 15gm tube just to keep in. Looks like useful stuff. I dont really want another car if this can be kept going. The rust looks bad to me and i'm no welder but is it even possible to weld repair an inner sill? There are pattern outer sills out there which could fix the overall appearance instead of a botched patch but as for the inner sill i've no idea. My V6 is also in need of similar work, must be the sea air and salty roads up here!
Mike
lexi
- x 134
Re: Mot failure ...
I kept many going with the welder over the years mind. I mean you can weld anything really, Inner sills , outer sills. Your car is probably saveable, but you need to be doing it yourself or a mate, to cut the costs.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
