Citroen dispatch
jason0110
Citroen dispatch
Please can you help I have a dispatch with 2 litre hdI 2006 and the cam pulley sheared off so I bought a 2003 expert with same engine running and paid some garage to transfer onto my 2006 dispatch . They put original pump on new engine and now it will only run on easy start and cuts out when you stop spraying . The only difference was cam pully on original had 1 bolt and new engine has 3 bolts on pully please help tia
Bick
- x 44
Re: Citroen dispatch
Hi and welcome to the forum - i take it from your post you are a little stressed out with your problem.
But i doubt i can help because if you have swopped over your pump and injectors and all the sensors i cant see why it doesnt start. Have you run a diagnostic? Do you have the immobiliser symbol showing on the dash?
jason0110
Hi I haven't swapped injectors would that make a difference with the old fuel pump thanks
Bick
- x 44
I think you can only swap the bare engine - all injection equipment will be coded to the immobiliser
