Advice on changing ax engine
Stusmiler
Unread post by Stusmiler »
Has anyone any thoughts on changing an ax cdy 1.0 spi 93 for a zx or similar kdx 1.4 is it a straight swap and would the ECU need swapping for the 1.4 version, thanks stu
x 2009
Re: Advice on changing ax engine
Unread post by Stickyfinger »
Most swaps will need an ECU swap as well. ALWAYS get codes etc for ECU's or you are getting a brick.
