Unusual noise C5 mk11 1.6 hdi
Bret Sinclair
Unread post by Bret Sinclair »
Did a service on my 2006 C5 hdi 1.6 110
Oil, filter,air filter, fuel filter, cabin filter, dpf and egr clean and a new lower crank pully. Since doing this I have noticed a weird noise when I pull away in first gear, like the first part of the noise a donkey makes ? If you are very slow to pull away, no noise, if quick to pull away, no noise but normal acceleration and it makes the weird noise. Noises associated with the lower pulley are non existent. Any ideas, cheers.
Bx 16rs
R11 Turbo
C15
Bx 19gti
Ax 14
Ax gt
Peugeot 305 estate
Bx d
Peugeot 406 coupe
C1
+ hundreds of other makes and models.
Bick
x 44
Re: Unusual noise C5 mk11 1.6 hdi
Unread post by Bick »
I wonder if when you fitted the crank pulley you did not tighten the serpentine belt correctly and its squealing a bit like you say a donkey LOL.
It could also be nothing to do with what you did and be the clutch - sometimes when you be nice to cars they complain!
x 5648
May also be the freewheel/clutch on the alternator.
taffy
Unread post by taffy »
i have a buggered dmf and it squueks on throttle and off also get that noise you talk about if i have too pull off quick sometimes im convinced its the dmf
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
taffy
at the mo i nearly had engine seize due to vehicle 23000 miles overdue service also starved turbo which snapped so removed inners so i can get to work and my god it struggles max 50mph max 2000rpm before power goes!
Bret Sinclair
Thanks all.
Does seem to be something to do with the clutch.
Further investigation will follow.
Bx 16rs
R11 Turbo
C15
Bx 19gti
Ax 14
Ax gt
Peugeot 305 estate
Bx d
Peugeot 406 coupe
C1
