'Sinker' pump reconditioning guide
- x 1486
On BXC, Gasa has posted a very good pictorial guide to pump reconditioning. It currently suffers from a bad case of automatic translation, but I will see if we can get the text unscrambled a little.
- x 8468
Re: 'Sinker' pump reconditioning guide
Useful to me as my sphere tester uses a sinker pump
- x 2009
No need Jim yours is working, just put some LHM in it..........
- x 8468
Stickyfinger wrote: 11 Aug 2017, 08:28
No need Jim yours is working, just put some LHM in it..........![]()
Yes, good point Alasdair
It did flummox me for a long while when it appeared to have failed on Monday
I need a sight gauge on the LHM reservoir perhaps!!!
- x 1507
Always check the easy things first....!
My mate's oil fired boiler stopped working, took at least 2 visits before anyone realised that the big red button on the tank gauge was to open the gauge to the tank. When this was pressed the emptiness of the tank was revealed in all its glory!!
- x 8468
I did Richard! I thought the LHM might be low and topped it up... A bit...
Still would not play... In the end it dawned on us that it needed a lot more topping up
You just can't get the staff these days
