Greetings,
I have been a fan of this site for a long time and never had reason to post...until now...but I'm confident someone will have the answer....
2. I have the dual zone air con, but I cant seem to get the zones to sync...on my 2008 when I moved the drivers side the one on the passenger side would follow the temperature, not the case with this one and there is no mention in the handbook or any trawling I have done. Usually there would be a "sync" button of some sort?
Any help is very much appreciated,
Kind regards, Kevin.
SAT Nav Offset and Sync Aircon
Kevlar
Reason: Sat Nav question posted in the Telematics section.
- x 6950
Re: SAT Nav Offset and Sync Aircon
If you have the Dual zone climate control, the passenger and driver's side heater controls are independent of each other. This is by design. There is no 'Sync' option.
Kevlar
Great thank you...puts my mind at ease.. Also apologies if I posted the Sat Nav in the wrong area!
- x 6950
No probs - I thought it better to put the other topic there - I've responded to that one too for you.
MikeT
- x 232
Re: Sync Aircon
The option (in my C5) is accessed from the radio MENU button and working your way to the relevant options on the central display. It's a PITA as it's a simple button push of the climate controls to UNsynch them, but a right palaver to get them back into synch as above.
- x 6950
There's no option for this on the X7 Mike - it doesn't exist.
MikeT
- x 232
GiveMeABreak wrote: 01 Aug 2017, 16:42 There's no option for this on the X7 Mike - it doesn't exist.
Wow, Citroen just can't make up their mind. It would drive me to distraction having to set two controls for the same effect.
- x 6950
Yes, my previous MKII, had dual climate and it would automatically set the Passenger side to the same temp as the driver - until the passenger adjusted their own controls. There was an option in the menu to configure this as you say, but it's a completely different system on the later C5.
