206 wishbone question...
ekjdm14
x 263
Unread post by ekjdm14 »
Quick question for anyone in the know, what's the difference between standard 206 wishbones & GTi/CC wishbones? Is the balljoint a different size or is it the length of the arm/track width? We're due for new wishbones on the front of our (mildly modified) 1.4 HDi and was pondering the difference between the two.
If the GTi/CC wishbones have the same size balljoint (so would fit the standard hub carrier) but are either a bit stiffer &/or slightly wider then I may fit those as the car is lowered & would benefit from a little extra camber at the front.
Cheers. (Oh, and just noticed the new load/save draft buttons. Van will be happy! :D )
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
