Xantia- is there a way tho switch power socket
aerodynamica
x 215
Unread post by aerodynamica »
Hi all does anyone know if the cigar lighter / power socket on a mk1 xantia can be made to power on/off with ignition by e.g. swapping fuse position?
Graeme M
x 1459
Re: Xantia- is there a way tho switch power socket
Unread post by xantia_v6 »
Yes, I think the fuse diagram in the handbook gives the required clues. F16 can be inserted in 2 positions.
see: http://www.kolumbus.fi/~w496119/xw/electric.htm
Mandrake
x 695
Unread post by Mandrake »
xantia_v6 wrote: 20 Jul 2017, 09:34 Yes, I think the fuse diagram in the handbook gives the required clues. F16 can be inserted in 2 positions.
Excellent link that should be stickied :)
You can change both the radio and the cigar lighter socket to be permanent live or switched live independently by moving their fuses. They're easy to find - apart from the shunt, there are only two fuses that can be moved to two different positions, (Three holes for the fuse legs) one for the radio and one for the cigar lighter.
I changed my radio to be switched live after it once ran the battery flat over a week of not using the car with the radio left on... :oops:
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 1459
Mandrake wrote: 20 Jul 2017, 10:01
I note that the Xantia World site has not been updated since 2004 http://www.kolumbus.fi/~w496119/xw/index2.htm . Does anyone know how to contact the owner of that site to see if he will give us a backup copy of the data?
aerodynamica
x 215
cheers :) I now have a switched power socket. It's to make the dashcam start and stop via power.
Graeme M
clydeowenp
x 19
Unread post by clydeowenp »
Excellent post which saved me a lot of time. I intended to rewire my lighter socket so the dash cam starts and stops when the ignition is turned on. Job made so much easier by just changing the position of the fuse!
x 1996
Unread post by Stickyfinger »
clydeowenp wrote: 03 Oct 2017, 19:21 Excellent post which saved me a lot of time. I intended to rewire my lighter socket so the dash cam starts and stops when the ignition is turned on. Job made so much easier by just changing the position of the fuse!
Yep, nice and easy :)......rubbish these PSA electrics compared to Michelin (oops, real Citroen) stuff :)
aerodynamica
x 215
It's good to know but I still intend to hard wire the dashcam to the switched circuit anyway. I wanted to run it off the cigar lighter for the time being to see how I got on with a dashcam.
I'm thinking of wiring it from the wiring at the sunroof motor.
Graeme M
Gingerposer
x 6
Unread post by Gingerposer »
aerodynamica wrote: 14 Oct 2017, 19:49 It's good to know but I still intend to hard wire the dashcam to the switched circuit anyway. I wanted to run it off the cigar lighter for the time being to see how I got on with a dashcam.
There's a possible solution which may make it easier - and involve less intrusion into the wiring loom.
I recently got a dashcam and wanted to have as little visible cabling as possible - I found there's a wiring kit available which piggybacks into the existing fusebox using a fuse adaptor. Basically you choose a fuse which is already ignition switched, and use the piggyback fuse holder to allow your dashcam to use this as a power source. Obviously has to be rated high enough to allow the original item to still be powered as well as the small draw which the dashcam uses.
Here's a link to the wiring kit
http://www.ebay.co.uk/itm/Car-DVR-Dash- ... Sw2AFZufhG
and one for just the piggyback fuse holder on its own
http://www.ebay.co.uk/itm/Add-A-Circuit ... SwR0JUPMc5
Installation took less than half an hour all in.
Ainslie
Current: Other non-specified Japanese vehicle
Previous French cars:
Xsara 2.0 SX (sold)
Xantia 1.8 Forte (still going strong)
ZX 1.9TD (deceased)
Pug 406 TD (unknown)
elma
x 284
Unread post by elma »
aerodynamica wrote: 14 Oct 2017, 19:49 I'm thinking of wiring it from the wiring at the sunroof motor.
I don't think that will be possible as the sunroof wiring will not have an ign switched live.
aerodynamica
x 215
That's a good solution Ainslie.
@elma
Is it only switched to the console switch ? I guess it would be then.
Graeme M
x 6945
aerodynamica wrote: 18 Oct 2017, 15:42 @elma
Elma is not active on the forum at present, so don't expect a reply - however if it helps, I installed front and rear cameras on my C5 X7 and I did a write up with pics here - it shows a similar kit that Ainslie refers to.
https://www.frenchcarforum.co.uk/forum/ ... t=dash+cam
aerodynamica
x 215
Nice one Marc, thanks very much!
Graeme M
Gingerposer
x 6
Did you go down the permanent wiring route?
Just curious :)
Xsara 2.0 SX (sold)
ZX 1.9TD (deceased)
