'09 C5 cabin fan....
milleplod
x 15
Unread post by milleplod »
....makes lots of noise when on its highest setting, but doesn't seem to produce a lot of air! :shock: Its nothing new, its been the same since I bought it I think, but I just wondered if 'they're all like that, sir', of if something's amiss. I did fit a new cabin filter earlier this year, but I don't remember there being more wind through my hair (or what's left of it....) prior to the change - if I'd put it in the wrong way round, could that affect output at all? :?
Pete
Nocto Diuque Venamur.
x 5673
Re: '09 C5 cabin fan....
Is there any possibility that the fan unit has been changed?
It has been mentioned that a Peugeot one runs in the opposite direction so if one has been fitted in error it may be the cause of the problem.
MikeT
x 232
Unread post by MikeT »
Compared to the Xantia, I felt my 05 C5r interior fan was a bit strained but maybe that's because it channels to the rear seats equally? I've learnt mid vents best for cooling me down.
But yes, at full speed it's bloody noisy! I usually only need two full blades at most, often less once the temperature has settled.
milleplod
x 15
myglaren wrote: 17 Jul 2017, 18:31 Is there any possibility that the fan unit has been changed?
I don't think so - I've got a folder with bills for everything the previous owner (he had it from new) had done to it...even bulbs are documented!....and there's no mention of it.
MikeT wrote: 17 Jul 2017, 18:40 Compared to the Xantia, I felt my 05 C5r interior fan was a bit strained but maybe that's because it channels to the rear seats equally? I've learnt mid vents best for cooling me down.
I'd never noticed rear vents tbh, must have a look for them! At lower speeds, there's output, but not much really. Perhaps its just me - previous cars seemed to blast air out when the fan was on full, even our 10-year old Doblo van's output matches the noise! :)
Pete
x 1940
Unread post by Paul-R »
On my C5 top speed is certainly noisy but also blows a gale. Could the fan blade possibly have come away from the shaft somehow?
milleplod
x 15
Paul-R wrote: 17 Jul 2017, 18:59 On my C5 top speed is certainly noisy but also blows a gale. Could the fan blade possibly have come away from the shaft somehow?
There's no odd noises, its a proper blowing sound...and at full speed there's plenty of air coming out of the vents, I just expected more...to go with the 'Learjet take-off' sound! :-D
Pete
