I have a 96 TD estate and the ride height across the car is out by about 1" when the car is on a flat and level surface. The trialing arms appear to be at the same angle and I am at a loss what the problem could be.
Is the rear suspension "tube" mounted on bushes and if so where are they? If it is bushes are these easy to change or do I need a lift for the job?
Any comments would be appreciated as it can be a bit disconcerting on long corners.
Regards
Andy
