injector removal help
doctle
x 223
Unread post by doctle »
I can't remove one injector to change a seal and I don't have a puller, any suggestions on how to remove it? Peugeot 307 with a 1.4 HDi engine, thanks
Oh buggle
MikeT
x 232
Re: injector removal help
Unread post by MikeT »
I've seen this method get a stubborn injector out of the 1.6hdi.
Penetrating oil, penetrating oil, penetrating oil. Best to soak over a few days
If the 1.4HDI has same injectors, they have a couple of flats on the upper body that a 24mm open-ended spanner fits from behind so you may have to remove other engine components to get the spanner on the injector. Using the spanner as a lever, gently but firmly rock the injector from side to side but don't use excessive force.
Repeat the above (oiling and rocking) until you can begin to lever the injector up by the clamping bracket. Again, avoid excessive force.
doctle
x 223
MikeT wrote: 11 Jul 2017, 13:56 I've seen this method get a stubborn injector out of the 1.6hdi.
That worked! The 1.4 diesel injector is smaller 13mm spanner fitted on the flats. It took a tin of brake cleaner, half a tin of WD40 and a can of coke to get it out. new seal and protector and all back together. Thanks for the link I was being quoted €3-500.00 for the job!
Oh buggle
x 3296
Great news, and well done.
MikeT
x 232
doctle wrote: 11 Jul 2017, 22:29
Great news and well done!
As you meantioned a saving, may I suggest you consider a small donation to this site? The Forum is provided by very kind volunteers and does have ongoing costs.
doctle
x 223
Yes I will, how does one make a donation?
Oh buggle
MikeT
x 232
doctle wrote: 12 Jul 2017, 00:06 Yes I will, how does one make a donation?
Here you go, and you can get some pretty car stickers in the process.
https://frenchcarforum.co.uk/fcf_landin ... icker.html
