Installed Headlight Switch / Signal Light Switch on steering Column...how to use Lexia to have the vehicle recognize?
AlvinCitroenC5
x 3
Unread post by AlvinCitroenC5 »
I am replacing the headlight / signal light switch assembly on my steering column. Can someone please let me know where in Lexia / Diagbox that I can teach the vehicle to recognize the new assembly so that the ESP will work properly in my 2005 C5 II V6?
Thank you.
x 1061
Re: Installed Headlight Switch / Signal Light Switch on steering Column...how to use Lexia to have the vehicle recognize
Unread post by wheeler »
From memory you go into ABS/ESP then programing then calibration of the steering angle sensor. It then guides you through the process.
