Hi.
If anyone knows or has technical document on how to remove the front left drive shaft, I'd be pleased.
I have previously removed front left hub to change the CV joint boot but now the inner joint is rattling a bit so I purchased whole new axle.
Going to change the oils to the transmission obviously but I'd like to know how to remove axle from the transmission, is there any cautions to be aware? Does it just come out by pulling like in some other cars?
Car is Citroen C5 X7 with 2.7hdi engine and automatic transmission.
Help needed: Front left drive shaft change procedure.
Finguy
- x 14
