Hello to all,
we are replacing the steering lock module on a Megane.
When we took off the plastic covers to reveal the module , the torx bolt on the module is hand-loose. We know its a left-hand thread, but it will not either tighten or come loose.
Any fail-safe method for removing it ?
Thanks in advance
Removing Steering Lock Module
xsaras4ever
- x 44
Jumper 2.5d
406 Phase 2 Estate, Hdi
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
Fordson Major Tractor
Nuffield 460 tractor
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
ekjdm14
- x 266
Re: Removing Steering Lock Module
So the bolt is free to spin but doesn't wind in or out?
sounds like the thread is buggered, only thing I can suggest short of drilling the head off is to try and get a bit of upward pressure on it while you slowly turn it clockwise (as it's LH thread) and hope it starts to "bite" on a good bit of thread. Can you get a small screwdriver/bradawl or similar, maybe even a broken sliver of feeler gauge to wedge under the head to lever it upward as you unscrew?
Obviously I don't know the build-up on this at all but if possible you could maybe punch it upwards from the end of the thread. Hope someone can suggest something more definite though
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
xsaras4ever
- x 44
Hello to all.
Got it out - Grabbed it firmly with a mole-grips - kept a pull on it - and turned it slowly with a torx key.
Out it came.
The captive nut on the steering column had come free. Probably someone previously had a go - didn't know that it was lefthand thread and ended up tightening it until the nut parted from the flange on the column.
Thanks to all.
Out it came.
Thanks to all.
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
