Best way to remove oil filter from plastic cover?
vonsworld
Unread post by vonsworld »
Hello
I've just changed the oil and oil filter on my Citroen Nemo, but had a few problems with the filter.
First of all it's awkward to reach from above with several pipes in the way, but once I removed the plastic filter cover I discovered the paper filter was stuck fast inside the cover. As you will know it is held by a circular ring of clips in the top of the cover.
I've never come across this wonderful design before ;-) since my previous cars have always had metal cartridge filters, but I understand this is a common design these days.
Anyway there is a video online showing you how to make a makeshift tool using the centre from a toilet roll, you create a tube to push inside the filter to release the clips. This didn't work for me because as soon as the oily filter touched the cardboard tube it went soft. However I cut up a plastic drinks bottle, made a suitable tube, and after several attempts the filter came loose.
There must surely be an easier way to release the filter, is there a trick I don't know, or a tool designed for this purpose?
Thanks for your advice :-)
DickieG
Monaco's youngest playboy
x 33
Re: Best way to remove oil filter from plastic cover?
Unread post by DickieG »
Either take hold of the filter with your hands and give it a sharp pull or insert a screwdriver into the side of the filter and lever it off, works for me every time.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Ed900
x 3
Unread post by Ed900 »
Pull really hard. Mine was stuck, thought I was going to break it. Think mine had never been changed :-(
I've no idea why they are fitted, probably to make things less DIY!
Bick
x 43
Unread post by Bick »
they can be a pig brute force required - screwdriver good idea or clamp the plastic housing in a vice (cover jaws with rag) and give it a sharp yank
MikeT
x 232
Unread post by MikeT »
I don't know what's different with mine but my filters always remain in place, which also causes the oil contents to leak all over my gearbox and everything in between
x 1489
Probably the fingers in the lid are broken!
Best to wear gloves when attempting this, or it takes a week to clean the oil off your hands....
MikeT
x 232
RichardW wrote: 29 Jun 2017, 19:46 Probably the fingers in the lid are broken!
I could see an array of fingers inside it, didn't look broken to me but I'll look closer next oil change.
Although I generally do use latex gloves, I can highly recommend Comma's Manista. I think it was Jim turned me onto it and I haven't looked back!
Bick
x 43
Dont screw it all the way out Mike until the filter has drained - just about the last thread and you will hear it draining leave to drain - no mess
MikeT
x 232
Bick wrote: 29 Jun 2017, 20:29 Dont screw it all the way out Mike until the filter has drained - just about the last thread and you will hear it draining leave to drain - no mess
Aha, that's the knack is it? Thanks, will remember that and see how it goes. I'll also put a beach towel below it next time, the common rag I used last tme just didn't have a chance :rofl2:
x 8397
I must admit, on my 207 it's never been an issue. Give it a good tug with a gloved hand and it comes out a treat...
