What does EOLYS actually do?
Harlequin
x 24
Unread post by Harlequin »
As title - what does it actually DO in a HDi engine?
Simon
MikeT
x 232
Re: What does EOLYS actually do?
Unread post by MikeT »
It "lowers" the combustion temperature of soot particles. IOW, the particles would not combust so well without it.
x 2008
Unread post by Stickyfinger »
MikeT wrote: 20 Jun 2017, 16:58 It "lowers" the combustion temperature of soot particles. IOW, the particles would not combust so well without it.
Does it ?.....I thought it attaches itself chemically to those particles and as the Eolys itself oxidises it acts as a "starter" agent for the soot particles............I may be wrong.
x 1955
Unread post by Paul-R »
It acts as an agent to reduce the temperature at which the trapped soot particles oxidise. I suppose it's correct in a way to say that the trapped particles wouldn't combust so well without it and they would then clog up the filter quicker.
On other marques that don't use EOLYS the combustion in the filter runs at a much higher temperature when the trapped soot is burned off.
MikeT
x 232
Stickyfinger wrote: 20 Jun 2017, 17:11
Not sure what you mean here Alasdair "the Eolys itself oxidises it acts as a "starter" agent"? AFAIk, the additive doesn't combust (oxidise as you call it), hence why the DPF has to eventually be replaced or professionally cleaned with other nasty chemicals.
x 2008
A catalyst to start the combustion of the particulates....................
MikeT
x 232
Stickyfinger wrote: 20 Jun 2017, 21:04 A catalyst to start the combustion of the particulates....................
Yes, it's a catalyst. I think we're agreeing aren't we? :-D
x 1955
I think we're all agreed on that.
Harlequin
x 24
So - if the EOLYS is in the tank (via the pump or squirted in) then it actually helps the burning process?
Simon
MikeT
x 232
Paul-R wrote: 20 Jun 2017, 21:56 I think we're all agreed on that.
I'm all for being educated and I guess the context of the OP question maybe needs refining as well but for the purpose of eolys additives role in diesel emissions. my poorly constructed laymans response suits me just fine. :)
x 1955
No implied criticism from me and I hope that you haven't taken it as that.
Harlequin wrote: 20 Jun 2017, 22:05 So - if the EOLYS is in the tank (via the pump or squirted in) then it actually helps the burning process?
Yes, exactly. The purpose of any catalyst is to help a chemical reaction (which is what burning is) take place at a lower temperature. Normally this is so that less energy is used to make a desired product. In this case it's the reduction in temperature that's important.
Harlequin
x 24
So EOYLS helps things burn . So what is the role of the DPF with it?
*leading question - I don't think my eoyls is being squirted into the fuel tank , ergo, if I drain some off and I manually put in 30ml a tank full)
Simon
x 1955
The DPF firstly holds the small particles in place and stops them exiting into the atmosphere. Then, when the filter is sufficiently clogged, the burning process is initiated and the filter holds the particles in place until they're burnt away.
Once the particles have been oxidised there's an extremely small residue of cerine and non-combustible matter left in the filter which will eventually mean the filter needs a very deep clean or even replacement.
