Rear ram bush
Dommo
x 20
Rear ram bush
Unread post by Dommo »
Hello all.
I've recently removed my rear ram for refurbishment as per Jim's guide. I was wondering what the consensus was with regards the ram bush, it doesn't clunk but has a bit of play in it, is this excessive and needs replacment?
Thank you all.
x 1999
Re: Rear ram bush
Unread post by Stickyfinger »
I would replace that personally.....either with a solid one or the Peugeot version of the standard bush.
x 8365
Re: Rear ram bush
Stickyfinger wrote:I would replace that personally.....either with a solid one or the Peugeot version of the standard bush.
Agree.
Dommo
x 20
Re: Rear ram bush
Interesting, what is the part number for the peugeot equivalent?
I have a left over home-brew bushing from my previous Activa which saw about 6 months use, so if needs be I'll just use that one.
Thank you all.
x 1999
Re: Rear ram bush
This one also....cannot remember the pug number atm
Dommo
x 20
Re: Rear ram bush
Thank you, that's great. On Servicebox it's only £16.08, bargain!
Cheers.
x 1999
Re: Rear ram bush
there you go :)
x 8365
Re: Rear ram bush
Time to get a load in stock ;)
Quackers
x 17
Re: Rear ram bush
Unread post by Quackers »
Is this an identical part then? I paid £150 for the rear ram bush part last decade on my last Activa.
My rear rattles a lot on my latest one so think it needs doing.
x 1999
Re: Rear ram bush
Yes......
