Anti pollution fault
Kevinseven
My c5 2009 wagon is showing a anti pollution fault not having any effect with car yet 'do I have to do anything or can I just get it removed by resetting the computer .it is a 2.7 twin turbo diesel I live in australia central coast
Dommo
- x 20
Re: Anti pollution fault
My C5 does this every now and then and it's always been EGR related. An ecu reset gets rid of it for a couple of months. Ideally I'd imagine your EGR valve needs cleaning
ekjdm14
- x 250
We have also had this with our 1.4HDi and that was EGR too, a quick clean of the solenoid connector & "excercising" the valve with a vac. pump got rid of it.
Having said that, ideally you'd want to get it on a Lexia/clone to make sure there's nothing else amiss but checking the EGR connector & pipework costs nothing. I have heard of cases where there was a tiny split in the vacuum hose & cutting the damaged end off/reconnecting cured it.
Also, what engine is this? might make a difference if it's petrol or diesel.
'96 ZX SX 1.9TD, White, 88k
'98 406sw 1.9TD, Cherry Red, 197k
'98 Ford Fiesta 1.3i 72k
'93 Ford Granada Scorpio 2.9i 135k
- x 3280
I can confirm (if it is a vacuum system) that a tiny hole in the rubber pipe will cause this problem (although other things can as well). Mickeymoon, when he took a look at my C5, found a tiny hole in the rubber pipe between the EGR and the steel pipe on the bulkhead. Fortunately it was at one end (about 1cm in), so he trimmed it back, connected the pipe back, and it has not complained since.
- x 1442
It could be anything... needs to go on Diagbox to see what it's upset about. Where are you?
Kevinseven
Thank you for your reply the motor is the 2.7 twin turbo diesel I am in Australia on the central coast
