Is the Bitron Unit doing something important ? Has anyone done a post-mortem on a deceased Bitron so as to establish what lies within ? As one who does almost all driving on quiet rural roads hundreds of miles from the nearest Citroen workshop (which I can't afford anyway), I would like to apply my engineering resourcefulness
to replacing quirky elements with reliable alternatives. And the Bitron (should we call it a ****ron?) is near the top of my list. But first, need to know what it is that I'm chewing on.
I have found something of similar appearance manufactured by Bitron, which has 2 relays in a 15 pin package at
http://www.bitron-ind.com/indexframes.html
Bitron or ****ron ?
- x 1046
DoubleChevron
alexx
I think that I saw something like the item "Engine cooling controller" in the engine bay of my Xantia. Will look again.
Anyway, it must be connected to brown temperature sensor on the thermostat housing and operates fans and temperature warning light. Also, it's connected to A/C system and operates fans accordingly and shuts down A/C in case of overheating. Or so ... Obviously, it can't be an item with only 2 relays.
Kered
PeterMann
