What a fascinating day to have a proper, methodical auto electrician here
This is what we found, this may help others
Fundamental my car has an intermittent feed to the injector earth's, this is through the 4 pin connector near the spare wheel plate
We found that a 4 pin black relay next to 'big blue' was very corroded and had stopped working
Also, there's a 5 pin oblong brown connector up by L/H wheel arch that was so sensitive that moving it, cut the engine.
HOWEVER, I now think that the final problem is the FUEL computer behind the glove box.
I've had this problem before, on G-GOO which I once owned and that too was a car rescued from long term storage
I'm going to fit a 'new' one and hope! Once again, thanks to Stan!!!!
Second part of post...
Does anyone have any concrete info on aftermarket management systems......kdfi????
My electrician was very confident he could install such a system, anyone know anything??
I bid you all good evening !
GTI Turbo progress of sorts and a KDFI question
Bilkob
- x 47
