XUD9 vs DW8 discussion
kenbw2
(Donor 2017)
x 24
Unread post by kenbw2 »
Might be opening a can of worms here, but I'm interested in what the opinions are around the XUD9 and DW8.
I know the DW8 is a the same bottom end as the XUD9, and both are pretty much the same capacity and horsepower.
Specific points I'm thinking are:
- Performance
- MPG
- Longevity/durability
- Noise
- Simplicity of repair
Discuss...
elma
x 284
Re: XUD9 vs DW8 discussion
Unread post by elma »
Xud9 simpler, better and feels more powerful.
Dw8 same thing, better emissions, a few extra bits to go wrong.
My choice xud9 every time, the older the better.
x 8386
elma wrote:Xud9 simpler, better and feels more powerful.
As an XUD9 driver and having experienced loads of them over the years, I fully agree with James...
kenbw2
(Donor 2017)
x 24
Same here. I've had 2 XUDs and never a problem with either engine - until the timing belt snapped on one at almost 250k miles :(
Wondering what to make of my new(!) DW8 one
Old-Guy
x 24
Unread post by Old-Guy »
Agreed. Pre-1996, no EGR and no engine ECU so entirely mechanical (Bosch) injection system; only use for a Lexia is to find which ABS wheel sensor is causing the ABS to go into fault mode (light on, no ABS). Oh, and one extra pony-power too.
demag
x 102
Unread post by demag »
The only thing I noticed was boot the xud and watch the smoke screen but the DW8 wasn't so bad.
Sent from my Wileyfox Swift using Tapatalk
Dave
Old-Guy
x 24
The only times I ever saw smoke visible in the (XUD) Xantia's mirrors was briefly after booting it up Haldon Hill (A38 beyond Exeter) after gently cruising down the M5; just a bit of soot on the turbine taking light as soon as the exhaust gets really hot. No problems passing the emissions smoke test - even at age 21 and a mere 130k.
elma
x 284
They're all a bit different. If they do good runs and have a short idle before being turned off they tend not to smoke. I've only had one smokey one and that was because I had a piston ring fail.
x 8386
Mine runs like a clock, very frugal and powerful but never smokes, even with the biggest provocations...
x 1746
Our BX19 NA never smoked, even when provoked, and sailed though smoke test at MoT time.
A fabulous engine, if you look after the cooling system. (BX XUD HG issues were largely due to lack of a proper header tank, IMO. We fitted one, and then had another 130k miles, trouble-free, even towing 850kg of caravan all over Europe.)
x 8386
white exec wrote:if you look after the cooling system.
Precisely, that and regular cambelt replacements are essential to a long XUD life Chris, along with frequent oil changes...
They then go on reliably for ever.. Mine's on 208K and as fresh as a daisy still...
ekjdm14
x 261
Unread post by ekjdm14 »
XUD every time. I can't speak for the 97k blown up lump, how it was treated & what caused the failure are unknown to me although the coolant was good and literally zero waterway corrosion internally, but the c.150k replacement NA passed emissions with a reading of 0.17 IIRC (permissible 1.51) and even fully loaded and foot to the floor to maintain speed up hills on the way back from Scotland I've failed to glimpse any smoke behind us. Only time I see anything from the exhaust is from a cold start it puffs a little black out. I believe one glow plug may have gone lame since installation though so even that may vanish soon!
In comparison there's one or two DW engined 206s round here and they do smoke. not much, but more than the Xant' & with less weight to haul too...
A well looked after XUD will just run & run, ours must have been pretty well cared for since after I changed the oil 500miles ago the oil on the dipstick is still translucent whereas on most diesels I've serviced the oil is black on the stick again as soon as the engine's been run for a few minutes.
I would also hazard a guess that if a well looked after 23 year old XUD was tested alongside an average DW8 the older engine would be cleaner running despite the EGR and all that jazz. Not that the DW8 is a bad engine, nothing with XU roots could be, but for my money I'd prefer a good XUD over an average DW8 any day.
And for the record, Lexia would be totally useless on our Xantia as we don't even have ABS! Not sure it'd talk to the airbag either since that has it's controller in the 'wheel & just gets an ignition +ve from the car AFAIK...
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
chinkostu
x 30
Unread post by chinkostu »
Not a fan of the DW8, essentially a xud with asthma. Egr sticks open or the needle lift shats it and then they're a pig to get going right. Mine was still tank volume after various fixes, had to unplug vac to egr as it made it kangaroo
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1746
Did I imagine it, or hasn't been reported that diesel emissions improve as well-maintained engines put on significant mileage?
ekjdm14
x 261
white exec wrote:Did I imagine it, or hasn't been reported that diesel emissions improve as well-maintained engines put on significant mileage?
Probably true in the case of the XUD, and likely other known long-lived diesel lumps like the Merc 5 pots and the like since with age & mileage they loosen up considerably and the components are only just fully "run in" by 100k or so. Makes sense that as that process happens the emissions would fall.
