Xantia steering knuckle
Raul
Unread post by Raul »
Hi
Can I swap a steering knuckle from hdi to td? The wheel bearing (or intermittent bearing) makes very ugly noise and I tought that I could use a steering knuckle from the donor car.
I also need to change the inner track rod end( right side). I practised to remove it from the donor car and eventually I managed to get it out but I broke the rubber booth. Can you recommend which brand to prefer to get decent quality parts.
Citroen gsa 1299 , 1982
Citroen gs 1,2 pallas 1977
Citroen xantia 1,9 td estate 1996
Citroen Xantia 2.0 hdi 90 2000
