Particulate Temperature Sensor fault - need I worry?
Sloppysod
x 386
Unread post by Sloppysod »
Hi All,
I filled my car up yesterday with diesel in a local supermarket garage (Asda), yes I know some people say supermarket fuel is rubbish, but all Fuel in the UK is made to the same standard.
Anyway, I drove home, 1 mile, left the car for an hour or so then went out again, 1/2 mile up the road I got the alarm 'Bong' and the error message "Engine Fault Repair Required". The fault this morning was my Particulate Temperature Sensor Fault, error report below, I have cleared the fault and am now waiting for it to reappear, so need I worry or is it likely to be just a random fault, I suppose only time will tell :roll:
INJ : Engine management ECU
.......P2032 : particle emission filter temperature sensor.
..........(id0527-M-DDC-THESAU-NOT-LOADED) : Short circuit to earth
..........(id0299-M-DDC-THESAU-NOT-LOADED) : intermittent
..........(id0528-M-DDC-THESAU-NOT-LOADED) : local
..........(id0529-M-DDC-THESAU-NOT-LOADED)
...............calculated load value : 070 %
............... Linearised coolant temperature : 064 °C
............... Turbocharging pressure : 1235
............... Engine speed : 1504 Rpm
............... vehicle speed : 048 kph
............... Intake air temperature : 027 °C
............... measured air flow : 0016 mg/stroke
............... Pressure in the rail : 0856 bar
............... atmospheric pressure : 001 mBar
............... battery voltage : 14.155 V
............... Time counter : 4294967296
............... Mileage : 087268 Km
............... measured air flow : 0435 mg/stroke
............... Flow of gas through the particle emission filter : 0082354 l/h
............... Temperature after catalytic converter : 0100 °C
............... Particle filter differential pressure : 0012 mBar
............... PEF differential pressure sensor voltage : 0522 mV
............... Particle emission filter differential pressure offset : 0002 cnts
............... regeneration of the particulate emissions filter in progress : Regeneration inactive
............... Distance covered since the last regeneration of the particle emissio
n filter : 0078 Km
............... Total additive quantity in the particle filter : 0003 g
Thanks in advance
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Sloppysod
x 386
Re: Particulate Temperature Sensor fault - need I worry?
Update - After 100+ mile the fault has not reappeared - :)
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 5650
Just a C5 being a C5 then :)
x 1987
Unread post by Stickyfinger »
Needs an Italian Tune.
The one time I have had that on my present car was on hard(ish) acceleration when cold.
Sloppysod
x 386
myglaren wrote:Just a C5 being a C5 then :)
Yes I guess so!! - if I had not had my diagbox kit, it would have cost around £70 just to be told, "nothing wrong mate!!"
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 5650
Mine has just had a couple of days being difficult with the central locking.
Had to help rescue my son when his motorbike first refused to start at the petrol station, then the throttle control fell off.
Went to get tools from my boot and it wouldn't open.
Driver's door the same.
Key just turned in the lock for a while.
After restarting it access to the boot was OK but driver's door continued to be difficult - 'fixed' by not locking the car.
All OK again now without actually doing anything to it.
dnsey
x 19
Unread post by dnsey »
If the DPF temp sensor fault recurs, unplug the sensor (back of the engine - a bit awkward) and withdraw and check the cable. I had the same intermittent fault due to the cable chafing and wearing through the insulation - easy fix once found!
Sloppysod
x 386
dnsey wrote:If the DPF temp sensor fault recurs, unplug the sensor (back of the engine - a bit awkward) and withdraw and check the cable. I had the same intermittent fault due to the cable chafing and wearing through the insulation - easy fix once found!
Thanks, will do that just to make sure nothing is wrong - added to my next scheduled check.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
