Hi, just bought a new phone and trying to connect it via Bluetooth to the cars system to stream music etc, problem Im encountering is the car can see the phone but the phone cant see the car. Has anyone got any tips ?
Ill list the process I tried to get it to work
Turned phones bluetooth on and made sure it was visible
Choose the option under communication to search for bluetooth devices on the cars screen, phone is found so tap the phone when displayed on the screen.
Previous phone was easy to connect so assumed same would be for other phones.
Peugeot 208 & Bluetooth
Zx79
- x 6950
Re: Puegeot 208 & Bluetooth
What Head unit do you have (post your car's VIN if you don't kow) and what is the make and model of your phone. That might help having a bit more info, and welcome to the Forum.
Zx79
Cars VIN is VF3**************[VIN obfuscated, can be read by forum staff]
Honor 8 pro is the phone.
Maybe ive missed something simple.
- x 6950
Ok, threw me a bit as you have 2 'O's which should be the digit '0'! Got there in the end though.
So you have a 208 5 DOOR SALOON 1.2 i VTi (EB2) Manual gearbox 5 with the SMEG Digital Radio.
I've checked and the system supports Bluetooth Audio Streaming, so it is possible your SMEG system needs a firmware update to support newer phones.
If you hold the MENU button in until the system description screen comes up, it should tell you waht version of software your unit has. Let us know what it says.
Zx79
Thanks, I typed it as written down in the book and did wonder about them, should have made a note of it from the chassis.
The software version is 3.15.B.R1
Is that right combination of letters ?
Thanks again
Thanks again
- x 6950
Ok, so there is a later version of software available. There is a video of a chap updating his below, or if you are feeling a bit feint at the prospect, you can always ask the dealer to do it for you. Sometimes they can order the update for you for a few quid - but the video shows the update process anyway
Zx79
Awesome thanks bud, was thinking Id have to send the new phone back.
Ill give the video a watch now.
- x 6950
They generally release new software to support new devices - hopefully yours will be included. They may also update the Bluetooth Profile as well - so it could be that your phone's Bluetooth profile is newer than your SMEG unit. Either way I hope this resolves the issue for you.
Zx79
Again I would like to say thanks, is really appreciated. Tested it was working and its all good.
For anyone else who might come across this if the first usb doesn't work try a second drive.
- x 6950
Result! Glad you got it sorted and thanks for letting us know the outcome - always helps others.
