Zf 4hp20 autobox question.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi all..
A quick and maybe simple one.. will a zf4hp 20 box mated to a v6esj vvt from a c5 mk.1 work perfectly fine in a 607 v6 esj vvt car.. the c5 is an 03 the 607 is a Y plater 2001..
A very sad...
1994 XM 2.1 d auto
x 1486
Re: Zf 4hp20 autobox question.
Unread post by xantia_v6 »
Maybe... But you need to check that the gear ratios and final drive ratios are the same. Xantia and XM 4HP20s are not interchangeable because the ECU detects the wrong ratios as a fault.
