coolant bleed points in a c5
fallguy1866
Unread post by fallguy1866 »
can anyone tell me where the cooling bleed points are on a c5 2.2 hdi diesel 2004 auto estate
411514
(Donor 2017)
x 40
Re: coolant bleed points in a c5
Unread post by 411514 »
I have the 2.0 HDI not the 2.2, and on the 2.0 there are two bleed points, the first at the back of the engine bay where the coolant pipes pass through the bulkhead to the heater matrix, and the second point (higher in the circuit) on the thermostat housing. I would bet that these parts are common to the 2.2 HDI, and so likely applicable to your engine.
Sam
2003 C5 2.0HDI 110
fallguy1866
thanks found them all done thanks x
x 1938
Unread post by Paul-R »
Were there two and in the same position as on the 2.0 HDi?
