Xantia connection problem to lexia
mustican05
Unread post by mustican05 »
Dear friends.
I can not connect to the suspension with lexia
Does the VN05N diode cause a hydractive lexia connection problem?
SM-N9000Q cihaz?mdan Tapatalk kullan?larak gönderildi
x 1486
Re: Xantia connection problem to lexia
Unread post by xantia_v6 »
I dI don't think that the VN05N will affect Lexia communication. Have you checked the relevant fuses?
mustican05
Which fuse? I dont know it
x 8466
Fuses that supply the Diagnostic Socket are the two 5A ones in the fusebox under the dash...
