ZX Washer jets
ZXturbo_Aura
ZX Washer jets
Unread post by ZXturbo_Aura »
my zx has had a replacement bonnet before i came into ownership and it does not have a windscreen washer jet, it just has a piece of tubing bodged to the wiper arm. should there be a washer rail on the arm as with the BX's? ive got some led washer jets off ebay so im goin to drill the bonnet and fit them, im just curious to know what is the correct set up...?
thanks
Dan
Stuart McB
Unread post by Stuart McB »
ZX washer jets sit under the bonnet not on top. They're right along the edge that butts up against the windscreen.
David W
Unread post by David W »
Yep they're plastic and snap into a square(ish) hole in the bonnet construction. Quite cheap from Citroen. Sometimes a pattern bonnet will have poorly formed squares that means they need glueing in.
David
