rt5 sat nav
adekee1
rt5 sat nav
Hello im new to the forum,hoping someone can help,I've got a 2009 407 with an rt5 sat nav,the screen showed to update but wouldn't take an upgrade,I waa told it could be the hard drive so I took the top off to have a look and somehow managed to tear the wire ribbon,after reading different forums it seems they do weaken on the fold,the problem has been tryin to locate a ribbon I found a place in Spain autotronics.eu,has anyone had any dealings with them or can advise on where to get one,many thanks,ade
- x 6945
Re: rt5 sat nav
Give the Clarion Centre a ring - they are UK based and are licensed repairers for Magneti Marelli systems including the RT5. They may well have a ribbon cable for you.adekee1 wrote:Hello im new to the forum,hoping someone can help,I've got a 2009 407 with an rt5 sat nav,the screen showed to update but wouldn't take an upgrade,I waa told it could be the hard drive so I took the top off to have a look and somehow managed to tear the wire ribbon,after reading different forums it seems they do weaken on the fold,the problem has been tryin to locate a ribbon I found a place in Spain autotronics.eu,has anyone had any dealings with them or can advise on where to get one,many thanks,ade
http://www.clarion-service.co.uk/cs/Ori ... pment.html
adekee1
Re: rt5 sat nav
Cheers marc I've been in touch with clarion and still waiting for a reply,hopefully they have one,autotronics say they can supply one it's just the payment procedure I'm not sure about,
Trainman
- (Donor 2018)
- x 43
Re: rt5 sat nav
Are you sure it's RT5? Does it have Bluetooth? If not its RT4
Although the same discs should work, the cables though are different
Steve
http://c6owners.org/index.php
