I'm dismantling a BE3 from a Xsara VTS and have got as far as removing the roll pin from the gear selector shaft (about 3/4 of the way down on CitroJims guide). The pin is different from the one in Jim's guide and another guide I've found:
https://1drv.ms/i/s!AsPATM9wtLRngd164BB1JxKSiJwpiA
I can't see how I pull it out and it's reluctant to be driven forward any. Bigger hammer required or different method?
BE3 Gearbox Rebuild Help
evilally
- x 3
'97 406 1.9TD, 314k.
evilally
- x 3
Re: BE3 Gearbox Rebuild Help
Ok, got there in the end by putting a large blob of weld on top of the pin and levering it out with a very large bar. No doubt this has resulted in many parts becoming scrap, fortunately I'm only interested in the 2 shafts. Is there an "approved" method for future reference?
xf1ref
- x 12
If I remember well the roll pin contains 2 parts, inner and outer roll-pins. First you have to remove the inner pin and after the outer pin.
http://www.eastment.net/BE3%20Gearbox%20Strip.htm
