Xantia Ball Joint
froggy
- (Donor 2026)
- x 4
Xantia Ball Joint
Hi, just replaced the bushes on the front of my S2 Xantia. My question is, I found it difficult undo the nut on the hub end of the wishbone. The nut would not undo . The nut and thread of the ball joint would spin together! is there ' a right way' to undo the nut, stopping the ball joint from turning. I ruined the ball joint by holding the shaft using molegrips
then loosening the nut. is there a better way? Terry ( the butcher).
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
ekjdm14
- x 261
Re: Xantia Ball Joint
Put a jack under the balljoint & put a bit of upward pressure onto it & it ought to grip on the taper that way
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
Timmo
- x 168
I normally undo mine with weight still on them, learnt from doing drop links is much easier to undo the nuts whilst pressure on them, on lock you can normally reach in to them,
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
elma
- x 287
I tend to use a lever on the wishbone to lock the balljont in position then undo the nut. If I'm not reusing the balljoint I just put an impact wrench on it and let it spin until the heat locks it.
citroenxm
- Fallen Hero
- x 70
Before even starting to undo them drop links too WIRE BRUSH them very well!!
All it is that locks them is rusty threads and crap in the threads too..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
falling-out-with-my-car
- x 25
Ahh some you get out easily and some you don't is a good thing they are not very expensive to replace. I used to use the forks of a ball joint seperator tool to take up the slack as I undo the but tapping the tapered edge in to hold the taper tight as the but loosens.
Sent from my GoFone_GF50X using Tapatalk
- x 25
Nut not but stupid phone.
van ordinaire
- (Donor 2017)
- x 402
Mmmmmmm! Some interesting ideas there. Must say I've always resorted to a strategically positioned jack - while offering a little prayer of gratitude it's not one of those cars with the inverted ball joints!
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
ekjdm14
- x 261
I would have thought keeping the suspension loaded up with a jack would work in that situation anyway?van ordinaire wrote:....offering a little prayer of gratitude it's not one of those cars with the inverted ball joints!
- x 8350
That balljoint taper is normally so tight it can be a right 'mare to split at the best of times...
My technique with all taper ball joints is to thoroughly wire-brush the exposed threads, soak it in Plus Gas and then start to undo...
I never fully undo but undo a turn and then do it back up half a turn. I then repeat it backward and forwards - as if I'm using a die to cut a new thread - and touch-wood the nuts always come off OK without breaking the taper...
If the taper does break then as Ekjdm says, loading it with a jack to make it tight again will often save the day...
But as I say, the real secret is in the backwards and forwards undoing method...
van ordinaire
- (Donor 2017)
- x 402
Only problem I've ever had was getting the split pin out (no longer an issue!) UNLESS the thing was so badly worn that the taper turned as soon as you looked at the nut. A combination of Jim's method AND a loading jack will probably get you out of schtuck - although once I had to resort to hacksaw.
Problem with inverted tapers is the difficulty in placing a jack where it'll do the job, without being in the way.
Tapers will always yield to slow, steady, judicious application of a club hammer, ideally, with another strategically positioned behind as an anvil, it's just a question of how many blows need to be delivered. If space is an issue, an old Kango bit makes for an excelllent 2' drift.
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- x 8350
van ordinaire wrote:Only problem I've ever had was getting the split pin out (no longer an issue!)
I remember those!!!
I still prefer them to Nyloc nuts if truth be told!
ekjdm14
- x 261
van ordinaire wrote:Tapers will always yield to slow, steady, judicious application of a club hammer, ideally, with another strategically positioned behind as an anvil, it's just a question of how many blows need to be delivered. If space is an issue, an old Kango bit makes for an excelllent 2' drift.
Our Xant' didn't even need that much, a couple of smart whacks to the wishbone end with the trusty old ball pein and they were practically falling out, made driveshaft removal a doddle compared to previous experience (helps a lot not having the usual steel spring to fight with when taking them in & out on HP Citroens too)
Whichever way the ball joint is facing, I find placing the saddle of the jack under the brake disc works well in most cases. Heck it's even better on a Xantia with the handbrake on the front! I tend to block the disc from turning with a screwdriver if it's vented, on cars with rear handbrakes
