Renault Fluence 2012
azooz24
Unread post by azooz24 »
Hello All
I own a Renault Fluence 2012
KM: 82000
Gearbox : automatic
the manufacturer never advise about replacing the auto transmission oil, however I am afraid about the gearbox damage in case the current oil loses its viscosity specifications....
on the other hand the authorized service center says that the tiny metal parts that are mixed in the old oil is healthy for the transmission gear,
please advise me what is the correct action?
Thank you
Ahmed
lexi
x 133
Re: Renault Fluence 2012
Unread post by lexi »
You may have a CVT auto box? I would get the correct oil from dealers and change it out. If metal parts were good for a transmission, we would be getting sold it in packets.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
azooz24
Thank you Lexi
I do not have CVT, its the old shape ( 2012 )
plz advise what is the good oil for this model, if that is needed to be replaced
thanks
lexi
x 133
Do you have an Aisin Warner box ? ie a proper auto box with epicyclic gears? If you do then Mobil do a fluid for that, or get the Renault part fluid. It may be the same fluid as used in 2012 Lagunas.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
