Citroen AX S1 Ball joints woes
jsp
x 12
Unread post by jsp »
Hi, my brake caliper bolt stripped and I bought a 15mm hub to replace. Somehow this is still to big for my ball joint.
Anyone knows what year an AX uses 15mm ball joints? I have seen 14mm and 16mm but, never 15mm....
ekjdm14
x 281
Re: Citroen AX S1 Ball joints woes
Unread post by ekjdm14 »
If it's anything like our old ZX, the hub/balljoint sizes are more a guide than a rule and they just seem to fit whatever is in the parts bin at the time. (our 1.9TD with PAS had 14mm balljoints, supposedly only used on 1.4 non-PAS I think. Spec for the TD was 16mm).
That said, I've not come across 15mm joints either in my experience they've either been 14 or 16 :/
'95 Xantia LX 1.9D-auto, Black, 123k
'96 ZX SX 1.9TD, White, 90k
'87 Nissan Sunny 1.3L, 63k
'12 Mini freebie project
jsp
x 12
uff ok going to refit 16mm then.
