Thanks in advance
Front Door Window
Sloppysod
- x 392
Front Door Window
Has anyone replaced the window glass, if so, did you replace the two clips at the bottom as they suggest? any other tips would be welcome.
Thanks in advance
Thanks in advance
Stu
Sloppysod
- x 392
Re: Front Door Window
Update, I bought a "previously owned" window from a 2008 exclusive and did not replace the clips, I think you replace the clips if you only replace with new (£328+vat) as they have to be glued into position.
The Job took no more than 1/2 hour from start to finish, most difficult part was getting the plastic door liner off to get access to the mechanism, a little heat from the heat gun softened the adhesive enough to free the liner, then the same heat again to reattach it later.
Stu
