Xantia Mk1 headlights relay location?
aerodynamica
x 216
Unread post by aerodynamica »
Hi all, I have a problem with one of the headlights, it blows the bulb and now the fuse. I there must be a short somewhere - I think it's either at the connector to the headlight block or inside the bulb fitting itself as the voltage measured at the connector is fine and at the bulb connector. I wonder if the dip and main have two seperate earths as there are two earth connections at the multi plug.
Graeme M
x 2008
Re: Xantia Mk1 headlights relay location?
Unread post by Stickyfinger »
his thread may help, I would strongly advise to rewire the headlamp circuit.............
viewtopic.php?t=52577
x 1506
Wiring diag in my BOL shows two earth wires at the lamp unit, but spliced together for a single earth (albeit one per light unit) at the main earth board behind the battery. There's no relay on MK1 lights - they are wired direct via the switch.
x 8463
Graeme, I can't now as I'm just waiting to start a 10k run but when I get home I can post up the full wiring diagrams if that will help...
Now to go and run in the rain... It's going to be fun!
aerodynamica
x 216
Thanks all, and good luck Jim!
Graeme M
x 8463
Here you go Graeme:
Headlights Circuit
Headlights Harnesses (Looms)
And the Component Locations
Run was good :) See my blog!
aerodynamica
x 216
Ah nice one Jim!
Graeme M
